Thread: Initial Design Check Please
Hi Trev,
No problem with questions that's why we are here to help each other and ask questions. Don't stop asking questions no mattter how daft they may feel, if your not sure ask.!!
Regards the rails and bearings then like eddy says 20mm tend to be a better size and not just for greasing, they make building the Z axis easier due to being taller and generally give better support with there larger bearings. The rails also sit on the profile better.
With the type then look on the Hi-win site and it will show the difference between the types, it's often very subtle differences like hole centres or bearing heights ratings etc.
Most use the HGH-CA for the slim type and the HGH-CW for the flanged wide type with standard pre-load Z0. If your wondering what pre-load means then it's the amount of pre-tensioning the bearings have when on the rails. Pre-loading removes any slop or play but at same time requires more force to make the bearings slide so we don't want it too high. Z0 is lower pre-load.
Those new to using profiled linear rails are often shocked to find that the bearings don't easily slide when on the rails but require a good shove and then stop quickly. This preload at work. Stand on the buggers and you'll end up on your arse as they work best under pressure and glide like on ice. .. Lol
If your buying from Ali express the look for Fred Lee. Personally I buy ballscrews and rails etc from from Chai at linear motion bearings but he doesn't sell Hi-win brand of rails, they are some other Taiwanese brand which can't think of at minute but they are very good quality do just the same job and a little cheaper.Last edited by JAZZCNC; 26-10-2014 at 03:03 PM.
26-10-2014 #2
Thanks guys for the help so far. ive scrapped and started from scratch. Ive based it heavily off the pics you posted Jazzcnc, they where a great help and have used 20 Hiwin rails as suggested. Ive done everything in 20mm ali and doubled up on the aluminium profile now. Ive still got a fair bit to draw like the lower frame and bed and stepper mounts with belt drives, and y axis ball screws. Unfortunately im off for a short break so im going to have to go cold turky from solidworks for the next few days.
im going to have to find a good source of 20mm plate next. I was talking to a close family friend about my project who is an ex tool maker so now i have access to his machine shop now which is a great help.
Thanks again all
Trev
06-11-2014 #3
Hi guys, ive done some work redoing the design as per the suggestions. The lower frame will be made from 50mm square steal box with 3mm wall. The total z axis travel is 120mm. Ive not drawn the bed yet but it will sit in the space at the bottom of the frame but also be adjustable upwards .
Ive still got some things to draw like the z axis screw and stepper ect and x axis stepper mounts.
Trev
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM
