Thread: Initial Design Check Please
Hello all,
Sorry for such a delay in my response, ive been quite busy with work, GF and other hobbies/projects. So i thought i would post a short update of where i currently am.
Ive got the machince properly mounted on the frame (epoxy leveled) and the steel is currently being painted Hammerite blue. Its not shown on the pics but its got all the brackets for the energy chain ect now, and ive turned some fittings that will take 4mm festo connectors for greasing the hiwin blocks and ball screws.
ive built my own psu, and integrated a pre made soft-start into it, it has relays that control the cap drain resistor (overkill i know) and the high voltage.
So now im currently wiring up my cab, ive done the schematic and tonight did the wires to the drives (there is space for the 4th axis when i get round to that) Ill insulate the terminals on the caps before i finish the cab wiring.
Trev
The Following User Says Thank You to Gotty101 For This Useful Post:
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM
