Thread: Initial Design Check Please
09-09-2015 #20
No won't hurt it them at all.
Also Suggest you wire the alarms in parallel so if any one trips it turns on a relay. Put the E-stop thru a NC contact of that relay.
This means the relay will reset when power drops and the drives will reset them selfs. Also you'll avoid any issues with voltage drop wiring in series can give and it's less stress on the drive transistors.
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM
