Thread: Initial Design Check Please
22-12-2015 #27
Thank you for the kind messages.
Ive just got some minor thing and the main build is over, then i would like to work on sheilds for the rails and screws, although im currently moving my stuff about as im moving out of my house on the 10th of jan and in to my new one some time in early march.
I had a few problems setting up the z axis last night where it would trip the stall alarm if it was moved quick. In the end i manually tuned the z axis pid current settings and it works a treat now, and tonight ive setup the soft limits and played about a bit. One thing is can you make soft limits default on at all?
Thanks for the heads up JAZZCNC, ive ran all the internal signal cables in belden shielded cable (all the gray wires), and all the signals out of the box are also shielded.
I have installed an EMI filter on the VFD power feed and a EMI filter on the Stepper supply feed. I know its OTT but i wanted to be sure and thought i may as well while i was working on it.
One thing ive been looking at is the vistacnc p4-se mpg which looks quite good, does anyone have any suggestions?
Thanks again for all your help and support, it could not have been done with out your help and support.
Trev
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Component Check
By manofgresley in forum General ElectronicsReplies: 1Last Post: 22-04-2014, 06:04 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
Newbie Initial Wiring/Setup
By Rikk in forum Motor Drivers & ControllersReplies: 3Last Post: 28-06-2011, 10:19 AM
