    Hi guys,
    Just an update to say im still alive and have not given up, ive finally moved into my house fully a few days ago, and managed to do some work on the cnc. One of the home sensors was faulty so i swapped that out and its running a basic g code file (although not cutting anything yet) fine. In the file i have though it starts with a tool change request, but the spindle carry on running. Is this because i need to code the macro for the M command?
    It homes and has softlimits so it does not hit the stop no matter what prox switches, the estop circuit works as planned.
    Ive got to plumb up the pump for the spindle coolent, the touch probe, front estop button and the mist coolant and we should be done.... Although ive started drawing up my 4th axis that will use a harmonic drive.
    Other than the list above, i guess i need to learn to use it now, but on question is how do i know if ive got the motor tuning right is there any guide or advice?
    Kind Regards
    Trev
    Nice to see you back on again Trev.
    Not sure what you are saying here but the spindle should start using a M3 and then to stop it use a M5.
    If you post the gcode file up then it could be checked.
    Beautiful machine by the way I think you should put it in the hall of fame http://www.mycncuk.com/threads/10066...inished+builds
    so that others can see it and get inspiration .
    Hi Clive,
    Thanks for the reply and the kind words. Yes the spindle starts and stops using the M commands. It may be the test gcode file i found on the net, ill upload it when i get home. I had read that the tool change macro is empty so you implement it yourself, which may be the issue and just a matter of telling the spindle to stop and start again when you say you have changed the tool.
    I will post it into the gallery once ive finished tidying it up and fitted the last bits. I cant wait to have a play with it :D
    Trev
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Are you using Mach3? I seem to remember a configuration setting somewhere that specifies action on tool change, and one possibility was, in effect, "do nothing".
  1. Replies: 25
    Last Post: 30-08-2014, 08:33 PM
  2. Component Check
    Last Post: 22-04-2014, 06:04 PM
  3. Initial thoughts on new build
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-01-2014, 11:05 PM
  4. Some initial questions....
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2013, 03:00 PM
  5. Newbie Initial Wiring/Setup
    By Rikk in forum Motor Drivers & Controllers
    Last Post: 28-06-2011, 10:19 AM
