Hi,thanks for your response,I'm quite happy with the performance of the machine so maybe the first option adding a bob and bypassing the controller is the best option for now. Would you know what bob I would need and where I could find the info for installing it etc? Any help is much appreciated.
Marc
Sent from my HTC Desire HD A9191 using Tapatalk 2
29-10-2014 #2
Take a pick!
There are lots of options, but the biggest thing will be are you going to stick with a Parallel Port, or go for USB/Ethernet with an external motion controller. If you go the latter, then you have to ensure it's got lathe functions, as not all motion controllers support things like threading.
To give you an idea of options/price ranges, it varies from cheap BOBs on ebay that will connect to a parallel port, to full blown motion controllers/BOBs like those from CS-Labs or Dynomotion.
Personally I use Dynomotion KFlops with a mix of Kanalogs, KSteps and Konnect expansion boards, however I can justify the expense, as my machines are making money reguarly. Also with the IO being 24V, it eliminates issues with interference causing false signals that you can experience with poor wiring when using 5V IO, as per most more hobby grade controllers.
For more hobby use, personally I'd recommend an Ethernet SmoothStepper (USB one works perfectly for over 99% of people, however I don't think it's worth the risk of being in that sub 1% in order to save a few pounds), combined with a suitable PMDX BOB. PMDX produce some of the best BOBs, and have quite a few options depending on what you need to connect.
As for wiring it in, if you can't find any guides/build logs here or over on cnczone, then I'm afraid you'll need to either figure it out yourself, or find somebody who can do it for you.
It would probably be worth taking some good photos of the existing boards and posting them up here, as others may recognise them and be able to help.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
01-11-2014 #3
Hi,I havnt replied sooner as i have been reading up on the pmdx boards and studying wiring tutorials on youtube etc, I have a much better understanding of what i need to do.I think i should go for the ethernet smoothstepper combined with a pmdx, i think the one i need is http://pmdx.com/PMDX-122 ,as for the smoothstepper, do they all do the same job or are some better than others? I think once i have these parts i will post a new thread like you say including pictures of the current setup,hopefully someone will recognise it and then maybe work out what needs to stay and what should go.I havent begun to think about he spindle yet,that area is still a blank! I have read that i may need another board?
Marc
01-11-2014 #4
There are only two genuine smoothsteppers, the original USB SS and the newer Ethernet SS, both produced by Warp9TD.
Anything else that happens to mention smoothstepper in the name (i.e. quite a few ebay listings), is not a smoothstepper. I think PMDX are official resellers, so if you go for a PMDX BOB, it'll most likely be worthwhile getting the SS from them at the same time, to reduce the number of customs handling fees you'll need to pay.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
CONVERSION: boxford vmc 300 mach3 conversion
By bigred5765 in forum Conversion Build LogsReplies: 14Last Post: 05-07-2018, 06:05 PM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
Anyone in Surrey willing to convert --- Boxford mill to mach 3
By Gasgasbones in forum Marketplace DiscussionReplies: 12Last Post: 19-10-2014, 10:25 PM -
GRP/Fibreglass info needed
By irving2008 in forum General DiscussionReplies: 23Last Post: 06-08-2014, 07:53 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM
