Thread: Machine Feet for my lathe
30-10-2014 #12
You are right about the tailstock as a primary reference it is inadequate. The first job would be to get the laser to point at a target at the tailstock end. When the dot doesn't move with the lathe turning (by hand) then the beam is directly on the axis. Then you can set up the tailstock centre, before checking the carriage. if you only want a relatively accurate level how about this one http://www.chronos.ltd.uk/cgi-bin/sh...html#a30316004
You can always put it on the bed, zero it and turn it 180deg to check for any slope.
Machine couriers,lathe
By dazza in forum Marketplace DiscussionReplies: 9Last Post: 04-04-2017, 05:01 PM -
Machine Feet.
By IanS1 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 15-08-2014, 09:41 PM -
Which is easier to machine on a manual lathe 12.9 or EN24 steel?
By newtoid1986 in forum Metalwork DiscussionReplies: 1Last Post: 18-09-2013, 07:20 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
