Thread: Machine Feet for my lathe
31-10-2014 #19
Thanks for the reply Eddy.
I guess I am mixing terms. The only thing I really am interested in is making sure the lathe cuts as straight and accurately as I can manage. So I think I need to be concentrating on getting the bed as flat (no twist) as possible.
I will level the cabinets first (to provide a solid base) then put the lathe on. Then shim between the lathe/base as required until the bed is flat?
I guess I am talking myself toward the more expensive level! It say an accuracy of 0.02mm/m which sounds crazy... Would you really be able to see that difference with a bubble!?!Last edited by cncJim; 31-10-2014 at 12:33 PM.
Machine couriers,lathe
By dazza in forum Marketplace DiscussionReplies: 9Last Post: 04-04-2017, 05:01 PM -
Machine Feet.
By IanS1 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 15-08-2014, 09:41 PM -
Which is easier to machine on a manual lathe 12.9 or EN24 steel?
By newtoid1986 in forum Metalwork DiscussionReplies: 1Last Post: 18-09-2013, 07:20 PM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM -
4th Axis running as CNC lathe using milling machine
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 21-08-2011, 10:34 AM
