    yeah, i get that, but surly you can see im a fussy twat haha
    This is how my machine is, you can see the direction of text on a work piece. When I designed that workpiece on my computer the text would be showing left to right.
    So is your's like that ? if so then it's normal.
    Quote Originally Posted by D-man View Post
    Wait till your asked to design text on one piece at all different angles & upside down and raised & sunken then you might get fussy.
    so its a case of just living with it
  5. #15
    If you were doing lots of it the same way then you might want to change but if you are working on different layouts I would say leave as is, quick rotate is select all press Ctrl +9 45 left, Ctrl +0 45 right
  6. The Following User Says Thank You to phill05 For This Useful Post:
  7. #16
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    I'm unable to do that due to running 2 motors on the x
    Then just change your ports and pins settings (and slave settings), so that you have two motors on your Y axis, and one on the X.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  8. The Following User Says Thank You to Ger21 For This Useful Post:
  9. #17
    Surely that just rotates vectors that you have created on the workpiece it does not rotate the workpiece. When I looked into this originally I could not see or find (google) anyway of rotating the job/workpiece. It would be great if you could rotate everything on the XY Datum.
    Earle
  10. #18
    Ger21's Avatar
    Quote Originally Posted by Earle View Post
    Earle
    You can use G68 in Mach3 to rotate the program 90°.
    BUt my preference would always be to configure the machine to match V-Carve Pro. Having to rotate anything should be a rare case, rather than the norm.
    Gerry
  11. #19
    Maybe part of the answer lies here; http://www.mycncuk.com/threads/8004-...ight=backwards
    D-man, how did this conclude ?
  12. #20
    Earle
    The Vectors are the workpiece!!
  1. vcarve pro 7
    By GeoDurie in forum CAD & CAM Software
    Last Post: 22-05-2014, 02:46 PM
  2. Workpiece illumination
    By cropwell in forum Workshop & Equipment
    Last Post: 29-09-2013, 10:21 PM
  3. Securing the workpiece
    By jrob3rts in forum Machine Discussion
    Last Post: 16-06-2012, 10:21 PM
  4. Vcarve to Mach3
    By jcb121 in forum Vectric
    Last Post: 01-04-2012, 05:21 PM
  5. Workpiece hold down by glue
    By Robin Hewitt in forum Machine Discussion
    Last Post: 30-09-2010, 08:22 PM
