  1. #21
    As Gerry mentioned i reversed ports and pins, however the workpiece is now inverted and im getting narrow letter (test) also when doing to i get rounded corners, not sharp ones
  2. #22
    ok so ive managed to get the T the right way up to where i want it.
    will i have to do the steps per again due to swapping the axis, and also with the T being very narrow
  3. #23
    Looks like your motor tuning calibration needs swapping over too. I'm guessing you've got different pitch screws on your x and y?
    That should sort out the narrow letter problem.
    Edit : Check your cursor keys for jogging from the keyboard too (hotkeys). You'll probably need to change those too.
    Si.
  4. #24
    The Vectors are the workpiece!!
    I just tried Ctrl +9 45 left, Ctrl +0 45 right in VCarve, it rotates the vectors but not the material (workpiece stock)
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #25
    Awesome, im running rack and pinion on both axis. however one is on a gearbox and other two on cncrouterparts drive pulleys
  7. #26
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    You shouldn't need to change your jogging hotkeys, unless you've already changed them to a non standard configuration.
    You will need to change your steps/unit, and accel and velocity settings if they are different for X and Y.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  8. #27
    Thanks guys i now have it the way i wanted it :)
  9. #28
    Eddy,
    Why would you want to rotate the material? I am working every day like this, I set the Job "stock" dimensions greater than the model sizes and square, set the origin to centre, create the part I can then rotate to any angle with ctrl 9 and ctrl 0 then F9 to centre create the toolpaths and cut no problems whatsoever.
    If I want a pair then copy and paste move 1 each side of centre.
    If I was on txt same as above you can rotate, move, scale reverse, and only toolpath and cut what you want.
    look at the time taken to rotate and screenshot only seconds.
ID:	13779   Click image for larger version.
ID:	13780   Click image for larger version.
ID:	13781   Click image for larger version.
  10. #29
    Eddy,
    I don't, I only have a demo of V Carve Pro, I was just pointing out that using the shortcut keys described by Earle, only the vectors rotate. You said the "the Vectors are the workpiece" which to my mind was not 100% correct because surely the material is part of the workpiece. Beyond that I care not a jot, I use F-engrave because it's free and does the job.
  11. #30
    The vectors are the workpiece that is the part you will cut and use, think of the "material" as your piece of paper you are drawing on, you only need to set the thickness of the material for the size of the part required.
  1. vcarve pro 7
    By GeoDurie in forum CAD & CAM Software
    Last Post: 22-05-2014, 02:46 PM
  2. Workpiece illumination
    By cropwell in forum Workshop & Equipment
    Last Post: 29-09-2013, 10:21 PM
  3. Securing the workpiece
    By jrob3rts in forum Machine Discussion
    Last Post: 16-06-2012, 10:21 PM
  4. Vcarve to Mach3
    By jcb121 in forum Vectric
    Last Post: 01-04-2012, 05:21 PM
  5. Workpiece hold down by glue
    By Robin Hewitt in forum Machine Discussion
    Last Post: 30-09-2010, 08:22 PM
