    Well if you get all the steel and fastenings etc for free then you may and it's a very slim chance just about do it. . . .BUT . . . It will be compromised in performance and abilty.!
    It will require great attention to detail when building to get even moderate accurecy. The inefficiency or the linear rails etc will require more power from motors to overcome any sticktion. Attention to little details of design like adjustments etc will be needed and you WILL constantly be chasing adjustments.
    One problem with the bearing setup shown, and I have built like this so speaking from experience here, is that chips and rubbish become a problem with binding bearings. The bearings wear quickly so need replacing often, on upside they are cheap, but still a pain in arse.
    To be honest to build anything like a decent machine that's worthy of the effort involved, which to be in no doubt is considerable, then £1000 is the minium needed to make it worth the trouble. If done correctly then your £1000 will earn it's self back in no time and really will be instantly in profit from day 1 as you could sell it for far more than it cost to build.!!
    My advise as always in this position is save up and spend that bit more. Even of you buy a chinese router for £500-600 like Eddy suggest's then you'll end up spending £1000 by the time you have replaced the spindle and electronics when they die.!. . . . And they will sooner rather than later.!!
    Thank you JAZZ!!! Given me the slightest of hope that this may be possible after all, although...after reading the rest of your post i'm not sure if that was your intention
    Just to confirm, when you say I have a very slim chance of pulling this off do you mean for building my dream steel router that pavlo had built in his build log or a smaller desktop router?
    From what I understand the main cost for my first build will be the electronics (drivers, motors, PSU, spindle) as the materials and parts for the frame I can get for free or build myself (including roller carriages and ACME threaded rod). As you explained this will compromise the router quality and performance ability however, do you think this will still be "usable" for some wood carving work as long as I pay a huge amount of attention to detail?
    The positive I see in trying this out (if there is any ) is that if worst comes to worst, I have myself a decent set of motors, drivers, PSU and spindle and a router which cost me nothing but time to build.
    Will start working on Solidworks models but do you think I should also start looking into the electronics now? In the build log he has used 3.1nm steppers, do you think these will still be OK with additional frictional load of the roller carriages as you had explained?
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. Belt driven CNC mill - some questions
    By Cyclonit in forum Milling Machines, Builds & Conversions
    Last Post: 30-04-2014, 12:39 AM
  3. New CNC mill build
    By AVRnj in forum Milling Machines, Builds & Conversions
    Last Post: 13-04-2013, 12:19 PM
  4. A few questions before I start my build
    By eclassic in forum General Discussion
    Last Post: 11-07-2011, 10:54 PM
  5. NEW MEMBER: Hi from rainy York - build plans/questions
    By bikepete in forum New Member Introductions
    Last Post: 11-10-2009, 07:43 AM
