So do you guys think that a lathe conversion is the way to got for me with my current budget? Is the round bed/old lathe setup I added a link to in my previous post (similar to the one I currently have) suitable for such a conversion?
14-11-2014 #2
In a word, no. That's not to say it can't be done as a purely intellectual exercise, just that the results will be disappointing, plus the cost of conversion will far exceed what the lathe is worth. And it won't be a quick exercise either.
As the owner of several pre-1930 British lathes I can tell you that the backlash in the lead-screws and the lack of rigidity in the bed/headstock/bearings/etc make it pointless. Manually operated, I know the machine's limits so know how far I can push it and leave some slack for the final finishing passes. They were very much a seat-of-the-pants exercise, feeling the tool/bed/headstock/bearing/workpiece deflections to creep up on the desired end diameter. A CNC machine simply cannot come close, it needs the rigidity and precision in the basic machine to start with.
14-11-2014 #3
Thanks irving, do you know of any other CNC projects I could work on which are within my budget? Been looking at plasma cutters which look interesting but I am guessing they are also expensive. If not, I guess I will have to just hold off until I can put atleast £1000 forward as per JAZZ's advice.
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
Belt driven CNC mill - some questions
By Cyclonit in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 30-04-2014, 12:39 AM -
New CNC mill build
By AVRnj in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 13-04-2013, 12:19 PM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Hi from rainy York - build plans/questions
By bikepete in forum New Member IntroductionsReplies: 13Last Post: 11-10-2009, 07:43 AM
