Page 3 of 3 FirstFirst 123
  1. #21
    So this is what arrived today:
    https://www.amazon.co.uk/dp/B071DXGG..._TE_item_image
    Must say I'm quite impressed. A sintered filter and a one way valve on the fluid line. Two needle valves and a 5/16" air line push fit. Rigged it up to a small air brush compressor and it works a treat. Obviously I need a bigger compressor to get max air flow but the venturi works even at air brush outputs.
  2. #22
    Quote Originally Posted by Will_D View Post
    First make it to work, then be impressed. I did my first one using chinese needle valve for 5$ and it ended breaking seal after 5 min. Now i use Italian made valve and have not had any problems since. Valve must be good or it will not work properly.
There are currently 17 users browsing this thread. (0 members and 17 guests)
  1. Misting Systems - where in the UK?
    By Chaz in forum Marketplace Discussion
    Last Post: 26-06-2013, 04:38 PM
  2. CAM systems
    By Rob Stewart in forum CAD & CAM Software
    Last Post: 05-08-2011, 06:24 PM
  3. Hypertherm Plasma Cutting Systems
    By Hypertherm John in forum Milling Machines, Builds & Conversions
    Last Post: 04-03-2011, 02:46 PM
  4. any one know about auto lube systems?
    By graffian in forum Milling Machines, Builds & Conversions
    Last Post: 02-03-2009, 05:52 AM
