Thread: router cutters for 2D/3D
01-11-2014 #1
hi im looking at some cnc router bits to buy and i need some advice since im new to this.
i want to be able to cut 2D parts and also do some engraving of texts. is the part below ok for text engraving, if not what could i use this part for.
http://www.ebay.co.uk/itm/ELU-E45114...item35c03ae249
is this the part below ok for 2D cutting? thanks. any further advice appreciated
http://www.ebay.co.uk/itm/ELU-HSS-TW...item35c0a4aa32
01-11-2014 #2
It might help if you mention what material you want to cut.
01-11-2014 #3
sorry, its for both softwood hardwood
01-11-2014 #4
01-11-2014 #5
Unless you want text where the bottom of the cut is rounded.
This is the best I've found for text, they also do a 60deg cutter if you want deeper or finer cuts. They come to a fine point for the smallest text. http://www.wealdentool.com/acatalog/...egree_718.html
They would do, but for rough cuts I use these cheaper ones; http://www.toolstation.com/shop/Powe...+x+12mm/p67412
Then for finishing use something better from Wealden or Axminster.Last edited by EddyCurrent; 01-11-2014 at 07:52 PM.
02-11-2014 #6
To cover the basic necessities You would like to have:
2D jobs:
- 3mm/ 1/8" and 6mm/1/4" 2 flute square end or fish tail , for general profiling. Fish tail is better for wood, 30 degree spiral upcut.
- ~20mm for pockets and surfacing , 2 flute square end
- 3mm/1/8" and 6mm/1/4" 45 / 60 degree V cutter or engraver for Signs and letters. 60 degrees is better, 90 degrees is for bigger signs and bigger size like 1/2".
3mm/1/8" 30 degrees is best for small details, molds from plastic and so, but breaks very easily, so better option is to be engraver/flat tipped/.
V cutter is not the same as engraving bit.
For smallish details you would need 1-2mm 2 flutes, and for deeper jobs you may need extended shank or long reach.
Its up to you but i prefer to have 2 types of each before mentioned.
One type is stub length, means 6mm shank and 6mm LOC , other is maximum LOC, 1/4 shank -1"LOC
Generally the best is to arm yourself at first with 3mm /1/8" solid carbide bits and cheap 6mm HSS
3D jobs:
-big cleaning bit
-1mm, 2mm, 3mm, 6mm, ball nose , dep[ends on the size and resolution of job. The bigger the shank, the better, same for the above list.Last edited by Boyan Silyavski; 02-11-2014 at 02:03 PM.
Router bits cutters for the Kress 1050
By Skydeals in forum Kress Milling MotorsReplies: 2Last Post: 28-10-2014, 09:25 PM -
TCT Router cutters in a mill running at 4000 RPM
By suesi34e in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-02-2014, 08:02 PM -
Router Cutters
By sfallan in forum Tool & Tooling TechnologyReplies: 20Last Post: 26-08-2011, 09:23 PM -
Wealden Tools enlarge range of spiral router cutters
By Routers in forum Manufacturer NewsReplies: 0Last Post: 01-07-2011, 12:42 PM -
Cutters for alu and mdf
By Tom in forum Tool & Tooling TechnologyReplies: 0Last Post: 16-11-2009, 10:26 PM
