    Yes a vfd would be required, I got this from a UC300 manual, this would be ideal because the easiest way to control the vfd is via the 0-10v.
    "The analog output 1. signal can be used for SP PWM (Spindle speed PWM), setting the
    SP PWM checkbox assigns the analog output 1. signal to the spindle speed PWM
    function. If this checkbox is set the proportional analog Voltage of the actual spindle speed
    PWM signal will appear on this analog output pin of the device. The range of the signal is
    0-10Volts"
    You do need to know the parameters of the motor such as voltage, current, etc. can you get a photo of the motor rating plate ?
  2. Wish i understood the terminology lol but ill get there, took a pic of motor plate for you if it helps, where about are you located ?
    Quote Originally Posted by Craiggillzzr1400zx10r View Post
    Here's some vfd's as example; https://www.inverterdrive.com/group/...r=Power|0.37kW
    The max revs shows 1370 RPM so as not to take it past it's working range that should be about the maximum speed to run it at and that's at 50Hz.
    The problem is that reducing the speed will also reduce the power so there's a limit to how slow it will usefully operate at.
    The vfd needs to be like this;
    Input 230V ac single phase
    Output 230V ac 3 phase
    Power 0.37 kW (minimum)
    About 200 miles North of you.
    Op your are trying to reinvent the wheel here. This conversion has been done lots of times on other forums, there are videos on YouTube and there is also a yahoo group. I would start by hunting down all the various build logs and find out which parts will work for you in terms of vfd's
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
    The limiting factors for safe maximum speed for an induction motor are the bearings, rotor integrity and rotor balance.
    A modern induction motor plate is generally marked with the speeds at 50hz & 60hz, these are neither minimums or maximums, the marked speeds on a motor plate are simply those at which the motor will run for the stated supply frequencies.
    Only by referring to the manufacturer's technical specification for a given motor model and power can you determine the maximum safe working speed, inverter rated motors will have the maximum speed stated as a percentage of those marked on the motor plate in the manufacturer's documentation, but not on the motor plate unless expressly stated as a "Max".
    I have made use of motor manufacturer data to set the maximum speed for my lathe and mills, all were rated in the manufacturer's documentation at considerably more than 100% of the plated speeds.
    - Nick
  6. Ok cool, so, if i swap the steppers to my new ones and wire them into their controllers as per diadrams that came out with them then wire the controllers into the break out board, i take it the motion controller wires to the break out board from that then a vfd will wire to the motion controller and be able to controll speed and dir ction of the spindle
    Then theres the limits/home switches and an emergency stop and and lights or door switches that wire to the breakout board, and lastly the power suply that wires to breakout board
    Then il have to get a copy of mach3 on a pc to get it all moving i guess
    Sounds so easy lol
  7. Gavztheouch, where are these yahoo groups and build logs you mention, like iv said im a complete novice and understand very little of the terminology etc, im not daft but its just not my thing an am trying to learn as i go so i can understand what and how it all works
  8. Gavzthetouch, could you forward me any links to the emco pc mill 55 retrofit builds or the yahoo forum groups you mention, any and all assistance is greatly appreciated as i want to learn how this all works myself
  9. Eddy, can you give me a bit more guidance please, am i right in saying i plug my computer into the uc300 motion controll via usb, then that plugs into the BOB by serial cable, then the stepper controllers/e stops/limits all wire to the BOB as wiring diagrams, does the controll wire for the BFD come from the BOB ?
    Thanks for any help in advance
    Sorry for the slow reply. This is the yahoo group I am part of
    https://groups.yahoo.com/neo/groups/emcof1mill/info
    Bear in mind the emco mill 50, mill 55 and F1 machines are very similar. So when you are doing your searching try all 3 machine model numbers.
    ADD ME ON FACEBOOKS
  1. CONVERSION: Emco Mentor Mill conversion
    By Ross77 in forum Conversion Build Logs
    Last Post: 13-01-2016, 06:40 PM
  2. VFD upgrade
    By paulus.v in forum Spindles & Drive Motors
    Last Post: 05-11-2014, 11:09 PM
  3. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  4. Emco mill 50 Y axis travel?
    By gavztheouch in forum Emco Milling Machines
    Last Post: 01-03-2014, 11:10 AM
  5. Replies: 2
    Last Post: 04-06-2012, 12:31 PM
