  1. #6
    When you say mill are you meaning a router type machine ?
    Numbers seems to be all over the place.
    Is the motor layout like this ?
    1 on Z axis
    1 on Y axis
    2 on X axis (X on one side and A on the other ?)
    If they are then X and A should have the same settings for a start because they have to work in harmony, the velocity and acceleration on A are too high.
    If the machine can't physically achieve the settings you've put it will loose steps
  1. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 03:40 AM
  2. x-axis on Orac losing direction
    By asto in forum Motor Drivers & Controllers
    Last Post: 29-03-2013, 01:22 AM
  3. Help! Steppers losing steps and making a racket under slow feed..
    By fasteddy in forum Stepper & Servo Motors
    Last Post: 06-08-2011, 03:03 PM
  4. Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
    By fasteddy in forum Motor Drivers & Controllers
    Last Post: 14-05-2010, 02:32 PM
