Thread: New Mill losing steps
Hi all.
Purchased a new mill to start small production prototypes and seems to be loosing steps In y axis.was only cutting model board at 1.5mm depth and 300 on feed rate.
Any advice How to prevent this much appreciated.
Luke
02-11-2014 #2
Need more info regarding make/model of machine.
Are you using Mach3 with it ? if so, what do you have the motor tunings set to ?Last edited by EddyCurrent; 02-11-2014 at 05:53 PM.
02-11-2014 #3
02-11-2014 #4
02-11-2014 #5
02-11-2014 #6
When you say mill are you meaning a router type machine ?
Numbers seems to be all over the place.
Is the motor layout like this ?
1 on Z axis
1 on Y axis
2 on X axis (X on one side and A on the other ?)
If they are then X and A should have the same settings for a start because they have to work in harmony, the velocity and acceleration on A are too high.
If the machine can't physically achieve the settings you've put it will loose stepsLast edited by EddyCurrent; 02-11-2014 at 09:40 PM.
02-11-2014 #7
02-11-2014 #8
Only one motor on each axis the 4th axis is detachable.so currently of the machine.what sort of feed should be reasonable for this machine currently only running 200 mm pm
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM
