it's not a typo, there are 09 series tips. You'll only get them from boxford as it's not a size that is carried by engineers merchants. I contacted boxford years ago about this and they wanted about £12 for one 09 dcmt tip, so as you probably guessed i gave them a miss. You can get a new 07 sized holder and a box of ten tips for around £50 from msc or cromwell.
The Following User Says Thank You to i2i For This Useful Post:
20-01-2016 #2
I ended up getting replacement inserts for most of the tools, and a couple of new ones from a set by Chronos. However, due to brain fade in a very cold work shop, I've managed to break the clamp on the parting tool which came with the lathe. It's a cut down Iscar SGTFL 1010-1.6. I can't seem to find any left hand 10 mm shank parting tools on line. A couple of places in the states sell the Iscar tool but they're asking over $120, plus I'm guessing the USPS cost is going to be prohibitive.
Does anyone know of a source of a 1010 LH parting tool ? The ones I have found have all been 1212 or above.
I've mounted a blade type Glanze parting tool as a trial but it appears to be around 0.8mm behind the centre line, so will need some careful shimming, and sits on the front of the turret in a somewhat ugly fashion.
I could fit a RH parting bit but the interference from the chuck jaws would mean I would have to part at least 15mm further away from the chuck than at present.
Adrian
20-01-2016 #3
What's the problem to mill or grind 2mm from the bottom of the toolholder.
21-01-2016 #4
Unfortunately I don't have access to a mill or grinding wheels.
Rather than try and force an alternative to fit, I've placed an order with ISCAR UK for a replacement tool holder.
Adrian.
22-01-2016 #5
Thats not a clean method.
But you can clamp a part like a toolholder between your chuckyaws and turn the bottom down.
You must centre it so you don't have a large imbalance and can't more then maximum 0,5mm per step, but its possible. A better method is to clamp the tool 90° false in your toolholder, and an endmill in your chuck, but if you only have 10mm, so its no option, because many tools have square, not rectangle shafts.
Another possible solution is, you make or let make a special adapter tool that looks more or less like a lying Y. On one side its 10 mm to clamp in the turret on the other side it have a 12 or 16mm Slot for the bigger toolholders.
Lathe Indexing Tools
By T0rnado69 in forum Metalwork DiscussionReplies: 13Last Post: 21-12-2014, 03:21 AM -
tools for 3d wood carving
By chris in forum Marketplace DiscussionReplies: 5Last Post: 18-01-2014, 04:23 AM -
FOR SALE: various milling tools
By chopper12 in forum Items For SaleReplies: 20Last Post: 06-12-2013, 07:32 PM -
Replacing Servo motors
By m_c in forum Motor Drivers & ControllersReplies: 15Last Post: 28-04-2013, 12:02 AM -
HDS End Mill Tools?
By Tenson in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-01-2013, 08:04 PM
