Thread: G-Code for Model Train
Hi guy's
Long time ago before CNC I used to make model trains and have a hammering to make another but using my CNC. Being not to good at writing code I was wondering if anyone out there has any written program G.Code for the running gear of a steam locomotive.
06-11-2014 #2
You want to be looking for CAD files rather than G code I would think, your CAM software will turn it into G code, are you talking about lathe work here ?
06-11-2014 #3
I would imagine designing your own CAD model of the gear and then generating the GCode from that would be the ideal way to do it. Of course, you can always try searching the net to see if there is anything like the gear you require.
06-11-2014 #4
06-11-2014 #5
http://grabcad.com/library/tag/locomotive
Just some links I found, don't know if it's exactly what you want but worth a look.
http://www.3dartistonline.com/news/2...motive-part-1/
http://tf3dm.com/3d-model/steam-locomotive-18738.html
http://archive3d.net/?tag=locomotive
http://www.3dcadbrowser.com/3dmodels...on=locomotives
http://www.3dvia.com/search/?search[...25994044316399
http://www.the3dstudio.com/product_s...rch=locomotiveLast edited by EddyCurrent; 06-11-2014 at 09:40 PM.
06-11-2014 #6
Thanks Eddycurrent these few links will keep me busy for a while a I try to work my way through them. I use Artcam 2013 so I will have to find a way to import some of the drawings and then break them down into the parts for a cutting list. Should be hours of fun and I hope a finished model at the end.
Thanks again.
Phil
NEW MEMBER: Model Engineering meets CNC
By Reg in forum New Member IntroductionsReplies: 3Last Post: 06-05-2013, 06:35 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
RFQ: 3D Model
By petesos in forum Projects, Jobs & RequestsReplies: 3Last Post: 01-01-2013, 10:31 PM -
NEW MEMBER: model engine builder in somerset
By Peter Griffin in forum New Member IntroductionsReplies: 7Last Post: 21-10-2012, 04:41 PM -
recommended 3d model software for cnc cutting?
By wyndham in forum General DiscussionReplies: 6Last Post: 01-01-2012, 05:28 PM
