Thread: Machining a double D
08-11-2014 #12
EDM would be expensive if you were paying someone else to do it, however if you've got time and are willing to build a machine, then it wouldn't be quite so bad, but it depends on what your goals are.
Another option could be to machine the shape as near as possible on a mill, then use a small shaper and custom cutter to cut the sharp corners.
Dealing with Ti isn't that much different from stainless. You've got to use sharp tools and ensure they never rub as it'll workharden in the blink of an eye. It also produces swarf with a far shaper edge than stainless, so you have to be careful handling it.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
wobble / wiggle on ballscrew double row angular contact bearing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 14-12-2013, 08:35 PM -
Video of CNC machining a double sided part.
By Shinobiwan in forum Woodworking Project ShowcaseReplies: 26Last Post: 17-03-2013, 11:23 AM -
Double gantry idea, What do you guys think?
By craigrobbo in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 25-12-2012, 10:01 PM -
Single or double??
By Wobblybootie in forum General DiscussionReplies: 7Last Post: 06-01-2011, 08:08 PM -
Double sided machining
By CraftyGeek in forum General DiscussionReplies: 7Last Post: 08-12-2009, 11:04 AM
