Thread: Any timbers to avoid?
There is no wood that can resist sharp carbide bit at the proper feeds and speeds and using a technique exactly for it. Its art .
Fretwork is difficult. Meaning that needs planning. What Eddy says is one way. Depending on thickness desired, material and size there are other ways:
-use V bit and route the design leaving 1mm of material bellow. Flip and surface or just sand it.
-use waste board and screw the material where possible
-use very thin double sided sheet tape.
-mount 2-5w laser diode and just burn it if thin veneer
-make your DIY Swivel Drag Knife Cutter
EXPERIENCE: Avoid dealing with Valuframe
By Shinobiwan in forum Trading Experience & FeedbackReplies: 0Last Post: 06-02-2013, 11:18 PM
