Page 1 of 3 123 LastLast
    I have been looking for the best router bits for shaping polystyrene for a long while however I still yet to find a good solution that is not crazy priced. The best I have found so far is these burrs from the USA at $40 each and which are supposedly carbide coated however it would be great if they were a bit longer.There is one but in the USA also I have found but runs in at $600 each !
    I have been looking every were to try and find out ho they do the spiky carbide coating but with no luck so as to possibly look into having something custom made possibly how ever no idea of cost or if it is even posable.
    as it is only for cutting foam would it be posable to have some made with the spikes just in steel and then heat treated? I have no real idea but just looking for options other wise it will have to be a long flute to do a ruff out and change for a final pass with a burr.
    Unfortunately not I'm looking for exactly the same as my picture just with the cutting depth to be about 3 inches rather than 1.5
    This seems to be the manufacturer http://www.saburr-tooth.com/index.htm can't seem to find any info on longer shanks on their site though. Do you need the whole burr to be 3 inches or just the shank? If you're happy with a longer shank perhaps you can have an adapter made, to give the effect of a longer shank, to fit your spindle
    Yes those are the ones I got, a longer shank would be a start but ideally the cutting edge wants to be longer . Many thanks
    What you are looking for is called a rotary rasp.
    Dave
    Thats definetely non stick teflon coating, similar to Freud .
    Now i i don't have something clear. Why use burs instead of some ultra sharp sharp micro grain carbide router bit, say 3 flute straight long reach?
    I don't see how you will route faster with these compared to normal router bit. Also if you insist on burrr just buy roughing bits.
    What size bit, depth of cut, speed and step over? lets do the calc here. cause i dont see it right using these bits on foam.
    there's these ones from France....http://www.hand-stitched-rasp-riffle...tre-25-mm.html
    Or this, I know it's only a ball but it's 30mm diameter? http://www.clasohlson.com/uk/Rotary-Rasp/30-9512
    Neil...
    Build log...here
    The burr style is a prity standard practice when working on surfboards. From experience I have had in the past normal fluted bits can tend to heat up after a long duration and coolant is not a option and on eps this can end up melting the foam which can make a right mess. The burrs also give a great surface Finnish.
    im open to ideas ?
    I played with the two burrs I have today and even the fine one seams good.
    No idea how hard or I fit would be posable but would it be posable to make a blank bit on a lathe and then coat it in some sort of abrasive grit? I'm assuming balancing would be the major problem?
    i would give you tons of ideas but you have to give me some data to work with
    What size burr, depth of cut, speed and step over you use now? Do you pocket or slot cut? What is your collet size ? Spindle kw and rpm? What speeds your machine is capable of? What rails and ballscrew ?
  1. Carbide cutters
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 24-01-2014, 10:57 AM
  2. PTFE coating small parts in the UK - one offs
    By dsc in forum Marketplace Discussion
    Last Post: 22-12-2013, 09:07 PM
  3. diy powder coating
    By dazza in forum Metal Finishing Techniques
    Last Post: 21-03-2013, 10:14 PM
  4. Protective Coating and Lubrcation
    By blueseidboy in forum Milling Machines, Builds & Conversions
    Last Post: 06-09-2010, 11:16 AM
  5. RFQ: Recommend waterjet, metal folding, powder coating shop
    By alanambrose in forum Projects, Jobs & Requests
    Last Post: 20-02-2010, 02:14 PM
