    The two burrs I have are 33mm cutting depth and 21dia 64mm overall The ideal would be something around 25mm dia 75-90 mm cutting depth 130mm over all
    I have a 2.2kw water cooled huanyang spindle so er20 collet so 13mm max using hywin 20 rails x is on mod 1 rack geared 3.2-1 rapid is set at 10,000 mm/min but capable of a lot more but to scared to set higher at the moment. y and z are 1610 ball screw set at 2500mm min and it is quite happy cutting at 2500mm/min. When cutting a surfboard it is basically just running up and down the length with very small y and z movements most of the time
    I remember somebody using plan drill bits for the purpose. A good bit like Dormer is quite balanced. Leave, flatten or ball nose the face. But a proper reamer I belive is what will do the job.
    As you can see bellow more or less the special foam cutters look similar.
    http://www.3dcutting.com/solutions/frogtools.html
    so why not just buy proper foam cutter or try some of what I suggest for a diy solution
    Look at this baby
    http://www.ballewsawandtool.com/inde...hk=1&Itemid=31
    The frog tools are pretty expensive at nearly $300 dollars befor shipping and tax and the other is only a max of 1/2" dia so a little on the small side ideally but maybe a possibility if I can't find anything else
    many thanks
    How big is your max size collet on the spindle?
    CNC routing and prototyping services www.cncscotland.co.uk
    ADD ME ON FACEBOOKS
  5. #15
    It's a er20 collet so 13 mm
    many thanks
  6. #16
    http://www.copycarver.com/images/Sab...Burr%20Set.jpgI found this picture so it looks like it is some sort of coating that they put on.
  7. #17
    There is no free lunch this size. You want fast, means you are making £££.
    Now you wouldn't like cheap not perfectly balanced tool this size on your spindle.
    Your best bet is custom tool, should be cheaper than what they want. Later can be re sharpened many times so that's even better money wise.
    But as you see the burrs are not the proper tool, even if they work fine.
  8. #18
    http://www.mycncuk.com/threads/6770-...r-milling-foam
    Here is a thread I started when I was looking for a simlier tool. I also looked into the frog tools but the cost was too high when I was unsure if I even had the ability to mill the foam parts I needed. After completing the job I would say that the vast amount of running time is actually in the final finishing passes and the rough cuts take very little time in comparision. I don't know what sort of finish and step over res you are going to use but I would suggest starting out with some cheap tools to get a feel for what you need to complete the job in an acceptable time.
    I bought some cheap indexable insert mills and also some pricey ballnosed mills but half way through the job I relised I could use the endmill to 3d profile and rough the part so the ballmill became redundant. Condsidering the ball mill was twice the price of the endmill it was a costly mistake.
    I also think you spindle and machine may not be man enough to take a large frog tool but I could be wrong. I just know even on my thermwood the larger tools cause a hell of a lot of vibration due to off balance tools and jerky machine movement. Burrs dont look like the most balanced tools available with all that carbide glued onto a blank at random angles.
    ADD ME ON FACEBOOKS
  9. #19
    Cheers many thanks I took a look at the thread. The burrs I have seam pretty well balanced there's certainly no noticeable vibrations and cut well at around 6-7000rpm I think the way to start is going to be getting a collet extender which luckily come in er 20 1/2" and relatively cheap and will allow me to use the burrs I have all be it having to do a few more passes and get me going then try a few other cheaper bits and and hopefully in the mean time save up for something a bit more specific when I know what works best.
  10. #20
    I have been playing with a variety of end mills slot bits and standard router bits and the pics are bellow. It seams unless you run at very slow feed rates you get a large amount of tear out with any of the conventional bits and that was with a variety of feeds and speeds.however with the burrs the spindle speed could be significantly lower and feed rate a lot higher and still giving a very clean cut with minimal tear out which is why I have been trying to persue them.
ID:	13851   Click image for larger version.
  1. Carbide cutters
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 24-01-2014, 10:57 AM
  2. PTFE coating small parts in the UK - one offs
    By dsc in forum Marketplace Discussion
    Last Post: 22-12-2013, 09:07 PM
  3. diy powder coating
    By dazza in forum Metal Finishing Techniques
    Last Post: 21-03-2013, 10:14 PM
  4. Protective Coating and Lubrcation
    By blueseidboy in forum Milling Machines, Builds & Conversions
    Last Post: 06-09-2010, 11:16 AM
  5. RFQ: Recommend waterjet, metal folding, powder coating shop
    By alanambrose in forum Projects, Jobs & Requests
    Last Post: 20-02-2010, 02:14 PM
