    hello wal
    have you had the screw off?is it definatley the ballnut/bearings and not the end bearings on the screw causing the z to lock up...i had exact same trouble on my old routers z axis and thought/swore it was the ballnut at fault til I removed the screw.
    Wal's Avatar
    Hi Deisel,
    Yeah, the Z was definitely in a bit of a state - had to clamp one end of the screw in a vice and get a spanner around the flange of the nut to free it up..! What I thought was going to wind up unusable has actually been working fine ever since - well - it's not as smooth as it used to be, but accuracy remains good enough for my purposes. The click on the Y I'm assuming is the nut, but won't know for sure until I dismantle the stages and have a closer look. We'll see.
    Cheers for the advice.
    Wal.
    Wal's Avatar
    I've had a closer look at my Y axis (with its .05mm of click) and in the spirit of finishing a story - it turns out that the problem lies with the FK12 ball-screw support bearings, which are rumbling a fair bit. Not great news, but a lot less hassle / expense to put right than replacing the screw and nut...
    As for my musings on the Z - well, I posted a while back that I wasn't entirely satisfied that the screw was straight - but once it was installed and working without any noticeable issues I was happy to leave it at that. In retrospect (and ignoring my erroneous 'theories' above) it's very likely that the run-out in the screw is what contributed to it seizing. There, the penny dropped. It took a while...
    New FK12's on order, will attempt to recondition the old as a spare set.
    Wal.
  1. Replacing the cuting tools on a Boxford TCL 160
    By Saracen in forum Boxford Lathes
    Last Post: 22-01-2016, 12:25 AM
  2. Replacing Servo motors
    By m_c in forum Motor Drivers & Controllers
    Last Post: 28-04-2013, 12:02 AM
  3. My first gear, a deadbeat escapement gear for my clock
    By clockman in forum Woodworking Project Showcase
    Last Post: 30-01-2011, 11:39 PM
  4. Buying British
    By Dopy in forum General Discussion
    Last Post: 05-11-2010, 02:45 AM
  5. NEW MEMBER: Greetings from Canada - Victoria, British
    By around in forum New Member Introductions
    Last Post: 13-10-2010, 10:13 PM
