Thread: hiwin rail question
20-12-2014 #19
I use this method all the time on hard to reach areas, even with 6mm nipples. Don't mess around with a syringe buy a small grease gun. Then put standard 6mm nipple on one end of pipe with threads inside the pipe and 4mm nipple on other end with nipple inside the pipe so can screw into bearing.
Then just connect 6mm to grease gun as normal. You'll need to wire the pipe to the nipples else the pressure blows them off.Last edited by JAZZCNC; 20-12-2014 at 12:04 PM.
mounting profile rail - Hiwin Manual vs. typical approach
By dsc in forum Rails, Guideways & BearingsReplies: 14Last Post: 11-12-2013, 10:43 AM -
FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
By Jonathan in forum Items For SaleReplies: 0Last Post: 06-11-2011, 05:26 PM -
hiwin profiled rail
By jonm in forum Rails, Guideways & BearingsReplies: 7Last Post: 07-08-2010, 06:48 PM -
Hiwin Profiled Rail Question
By Normsthename in forum Marketplace DiscussionReplies: 8Last Post: 02-08-2010, 07:02 PM -
WANTED: WANTED: HIWIN LG25 rail
By Smiler in forum Items WantedReplies: 1Last Post: 01-03-2009, 08:13 PM
