  1. #22
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 23 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    Eddy
    Think what siliavski means is drill the end of the rail along its length offset so you don't intercept a securing bolt drilling, then drill down from the top of the rail to intercept the hole, drill & tap the end drilling for a nipple, so home all axis and grease six nipples, never seen the 15mm rails up close but you might be able to get a 3mm hole in it & that should be more than adequate for wheel bearing grease.
    Regards
    Mike
  2. The Following User Says Thank You to mekanik For This Useful Post:
  1. mounting profile rail - Hiwin Manual vs. typical approach
    By dsc in forum Rails, Guideways & Bearings
    Last Post: 11-12-2013, 10:43 AM
  2. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  3. hiwin profiled rail
    By jonm in forum Rails, Guideways & Bearings
    Last Post: 07-08-2010, 06:48 PM
  4. Hiwin Profiled Rail Question
    By Normsthename in forum Marketplace Discussion
    Last Post: 02-08-2010, 07:02 PM
  5. WANTED: WANTED: HIWIN LG25 rail
    By Smiler in forum Items Wanted
    Last Post: 01-03-2009, 08:13 PM
