    I don't really see what all the fuss is about, it's just a few tubes and simple parts to make on a lathe? I guess if you've not got a lathe then that doesn't help matters.
    In my build log all the bearings and ballnuts are connected with tubes look towards the end of the of the first post in the thread:
    http://www.mycncuk.com/threads/6484-...8616#post48616
    The Y-axis rails are the same size as yours.
    Jonathan - am I correct in thinking that all the oil pipes go direct to the sliding carriages/ball nuts? Presumably you also had to be careful about routing pipes and allowing enough slack for movement.
    And for anyone who does not want or does not have the facilities to make the components, Arc Euro Trade (and probably plenty of other places) sell all the bits. I have a central lubrication system on my vertical mill, and it does mean that the slideways get lubricated much more often than when I had to do it all manually. It's a thought...
    That's fine if you use oil, but I'm on about grease. Tell me this though, does the oil drip about all over the place ? it's okay for you people who cut metal but I'm cutting wood and the last thing I want is oil contaminated wood, that's why I use grease.
    Yes and yes, but slack for movement doesn't present much of a challenge as the only pipes that move are the two connected to the gantry, which can be routed with the Y and Z axis motors. The challenge is when you have rotating nuts...
    If you put plenty of oil in then yes, it goes everywhere. Perhaps it could be managed with more careful control of the quantity.
    If you over fill with grease it comes out and the same is true with oil. The trick is to regulate the flow or pulse small quirts at regular intervals so just enough to coat the bearings with fine smear on rails. It's not difficult really.
    My mill as got programmable lube system which can pulse the pump and it just oils the bearings and ways nicely with very little to no excess, certainly not enough to contaminate anything.
    You can buy these cheap enough now and they even do ones which will pump grease.
    Same thing could easily be made with an arduino cycling a pump.
    You can do a central lube system and still use grease. Our Morbidelli has one.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. mounting profile rail - Hiwin Manual vs. typical approach
    By dsc in forum Rails, Guideways & Bearings
    Last Post: 11-12-2013, 10:43 AM
  2. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  3. hiwin profiled rail
    By jonm in forum Rails, Guideways & Bearings
    Last Post: 07-08-2010, 06:48 PM
  4. Hiwin Profiled Rail Question
    By Normsthename in forum Marketplace Discussion
    Last Post: 02-08-2010, 07:02 PM
  5. WANTED: WANTED: HIWIN LG25 rail
    By Smiler in forum Items Wanted
    Last Post: 01-03-2009, 08:13 PM
