Thread: 2D AND 3D Software problem
22-05-2009 #2
the buildings file is 2D just the plots not the complete building, therefore has no z-info. Yes you could adapt the file to extrude each building plot by a fixed amount, but what Ed needs is for each building plot to set the Z origin to the contour height at the centre of that plot and then adjust the Z cut to be a fixed depth from there into the surface. It could be done at the G-Code level but you'd need to emulate the landscape tool path and watch for the intersect with a building plot and then use that to adjust the g-code for the building plot (i.e. the pocket).
It would be better to do at the .stl level, not least because its easier to find the intersects and also because it could be reviewed/visualised before machining.
22-05-2009 #3
Yeah exactly. I've doing it the long way like you just described. It's the software i'm after more than anything. Will see if i can find a suitable file.
22-05-2009 #4
Powertran VFD problem
By phill05 in forum Spindles & Drive MotorsReplies: 7Last Post: 29-10-2013, 07:59 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
VHD Mounting problem
By PWD in forum Spindles & Drive MotorsReplies: 8Last Post: 25-11-2012, 10:29 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
