Certainly looks like morse taper, and the dimensions you give suggest MT3. So the collet chuck you pointed to should work OK, especially as it also is M12 for the drawbar. You might be looking for ER20 because you already use that collet size somewhere else so you have a range of collets, but ArcEuroTrade sell ER25 collet chucks on an MT3 shank. However, I suspect that ER20 will hold as big a cutter as you would want to use on that machine - it will take a 1/2" shank cutter; ER25 goes to 16mm/5/8". Main advantage of ER25 is that you can also get a ball-bearing collet closing nut which makes it a bit easier to get a good grip on tools but in this size, it probably doesn't make a lot of difference.
I've been happy with various things I've bought from RDG in the past, although Arc Euro aren't bad either.
13-11-2014 #2
ive also brought from RDG, and had good service, but i got my collect chuck kit from chronos, while i was there collection a rotary table a while back.
worth a look to see what deals they have on.
FOR SALE: For Sale, Chinese 1.5kw spindle (er11 collet) with matching VFD! with 4 & 6mm collet
By jcb121 in forum Items For SaleReplies: 1Last Post: 29-01-2013, 11:05 AM -
FOR SALE: ER20 DIY Spindle Parts
By Mad Professor in forum Items For SaleReplies: 1Last Post: 03-11-2012, 06:51 PM -
FOR SALE: ER20 collet set 12pcs (2mm-13mm)
By rbs in forum Items For SaleReplies: 2Last Post: 17-06-2012, 02:07 PM -
WANTED: ER20/25 straight shank collet chucks
By m_c in forum Items WantedReplies: 4Last Post: 24-10-2011, 12:19 PM -
ER20 Collets
By audioandy in forum Tool & Tooling TechnologyReplies: 6Last Post: 05-08-2009, 10:15 PM
