  1. #12
    It's very possible to build a decent machine from wood, contrary to what you're hearing.But it won't be easy.
    I watched a TV prgramme this week called "Wheeler Dealers", they bought a car from the US, a 1969 Carmen Ghia. There was not one bit of rust on it, and as the presenter said, in the UK there is no way that could happen due to the weather. I think it's the same with these wooden machines, most I see are in the US and not subject to UK atmospheric changes.
    Quote Originally Posted by Sven View Post
    . . .Then again, people suggesting to go with steel also say it is "easier" because they are used to working with steel. But OP is used to wood.
    I found steel and aluminium to be no harder to work with that wood, in fact steel is easier because mistakes are easy to repair with a welding rod. Aluminium is like using hardwood, I used woodworking tools for all my milling and cutting operations on it.
  1. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  2. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  3. Hardwood Supliers?
    By Stickio in forum Marketplace Discussion
    Last Post: 06-01-2011, 11:21 AM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
  5. Some thoughts on budget workshops
    Last Post: 02-08-2009, 04:11 PM
