Thread: Small metal airsoft part
The part could be machined with a 3 axis milling machine from a piece of angle-section stock.
- Nick
16-11-2014 #2
With respect to Blackrat, I wouldn't TIG as there is too much heat going into a small part, you are just asking for distortion, but maybe Blackrat is just a much better welder than me :). I would agree with Nick and 3axis mill. I wouldn't use angle or box section though as they are extruded from a gummier aluminium, go with a block of 6082 T6, the part is small so material will be cheap. Nothing too technical in the drawing though so someone local should be able to sort you out. Start with a block, mill with the "from left" view facing up, saw off, flip and skim to 2.7mm.Might need a basic jig though to prevent chatter by picking up on the hole.
Best of luck with it.
On an aside I think you should rename "Front View" as "Back View" for the left/right to be correct. I'm not trying to be a pedantic ass but it's important to prevent ambiguity if you send the part to someone for machining. (But I could be wrong, it might be some 1st/3rd angle thing I missed)
Rgds,
Noel.Last edited by corkcnc; 16-11-2014 at 01:10 AM.
16-11-2014 #3
Noel,
Angle, Box, Tube, Plate & Bar are available in the composition of your choice, my supplier only stocks structural grades as standard and so hasn't sold me any "gummy" stock yet ;-)
Google searching "6082 T6 Angle" reveals many stockists, ringing round might even yield a free or cheap sample large enough for the part in question,
Regards,
Nick
16-11-2014 #4
I wish I had your supplier local, Nick. I have to use ebay for anything "exotic". :) :).
Small metal Lathes / IE 350 to 50W machines
By dudz in forum Lathes, Lathe Rebuilding & ConversionsReplies: 43Last Post: 21-08-2013, 09:11 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
RFQ: Request: 200 units of a small part
By craynerd in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-02-2012, 10:25 AM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM -
Request for two small steel rod-esque lathed part!
By HankMcSpank in forum General DiscussionReplies: 42Last Post: 29-06-2009, 02:32 PM
