Thread: Small metal airsoft part
Im a little too busy but having a quick look at the original part below and with them being plastic is the gusset that reinforces that pin/upright needed?im not sure what kind of stresses it will be under but if it were made in aluminium??..could the upright be replaced with a brass pin or cut down stainless bolt so made in two parts or does it need to be square and shamfered like you drawn. it seems a simple part to make out of a bit of plate or billet and like said a bit of a file where needed using the old one as a template seeing as its a one off.
http://www.bullseyecountrysport.co.u...oly-9749-p.aspLast edited by dazza; 16-11-2014 at 02:38 PM.
Small metal Lathes / IE 350 to 50W machines
By dudz in forum Lathes, Lathe Rebuilding & ConversionsReplies: 43Last Post: 21-08-2013, 09:11 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
RFQ: Request: 200 units of a small part
By craynerd in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-02-2012, 10:25 AM -
WANTED: Wanted: Small Metal Work Milling Machine
By 07trb in forum Items WantedReplies: 0Last Post: 04-03-2011, 06:58 PM -
Request for two small steel rod-esque lathed part!
By HankMcSpank in forum General DiscussionReplies: 42Last Post: 29-06-2009, 02:32 PM
