    Hi there.
    Just to double check, is this the hop up arm for the ICS L85/L86? If so I am very interested in a metal one as the plastic one is not great. Is it possible someone could make one for me, name a price though first!
    Thanks.
    yes, this is designed for my ICS L85 (I assume that the L86 has the same hop unit, though i haven't checked).
    if you do want one, make sure that you use the revised model, attached to the post above yours, as the first version was a pain to install due to my own stupidity (I had to take a Dremel to it).
    its also worth saying that since i have changed the model after installing mine, i haven't actually tested the updated version, so be prepared to "Adjust" it, if necessary, though i hope you shouldn't need to.
  1. Small metal Lathes / IE 350 to 50W machines
    By dudz in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-08-2013, 09:11 AM
  2. RFQ: Very simple small part
    By Shinobiwan in forum Projects, Jobs & Requests
    Last Post: 11-01-2013, 01:02 AM
  3. RFQ: Request: 200 units of a small part
    By craynerd in forum Projects, Jobs & Requests
    Last Post: 13-02-2012, 10:25 AM
  4. WANTED: Wanted: Small Metal Work Milling Machine
    By 07trb in forum Items Wanted
    Last Post: 04-03-2011, 06:58 PM
  5. Request for two small steel rod-esque lathed part!
    Last Post: 29-06-2009, 02:32 PM
