Thread: Holding vice to table advice
How wide are the slots? I've got some small 6mm or 10 mm thick (cant remember which) home made clamping bars I've made. What's the bolt diameter too?
20-11-2014 #2
OK
What you need is some substantial flat bar (4 off) say 25mm wide and about 10mm thick and about 50mm long,
if the slot in your vice is less than 10mm wide you will need to machine the end of the bar so it will fully engage in the slot. you now need a hole in the bars for your "T" studs, say 20mm from the end of the bar that locates in the vice slot.
You can now either add packing a tad higher than the hieght of the vice slot from the table, and with a nut on your "T" stud just tighten, you could also drill and tap the other end of the bars 10mm and jack it that way but don't forget packing on you milling table.
Regards
Mike
The Following User Says Thank You to mekanik For This Useful Post:
20-11-2014 #3
10mm between the lips. Bolts are M6.
Did a bit of googling to see if I could buy some appropriate clamps but came across this - looks like a easily hackable solution with a few bits of plate I have lying around until I can make something more like this.
Also, just a note for anyone thinking of getting one of these vices... I've read a few people saying to put a bit of paper underneath before clamping?!
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
Milling vice, general milling vice or tool vice?
By Web Goblin in forum Tool & Tooling TechnologyReplies: 4Last Post: 15-12-2012, 11:15 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Advice on new table and ball screw.
By D-man in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-07-2012, 10:45 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM
