    Maybe like this ?
    I was thinking more like this so it looks old school.
    Well I'm sorry to say that if you can't do something so simple as making a standard ruler then you really do need to get practising not using off the shelf DXF's.
    Just making the rule marks would be a simple and easy execise to write G-code by hand let alone using a dedicated CAD/CAM program. IE: For 150cm length x 30cm width ruler using 6mm ballnose For 1cm rules 50mm long with 100mm long rules every 10cm set in 30mm in from the edge.
    (This simple example code doesn't include cutting out the profile and presumes x0y0 is bottom left corner of ruler and z0 is material surface.)
    G0 G40 G49 G80 G21 (Initialisation)
    z20 (safe travel distance)
    x30 y30 ( Rapid move to start point)
    z0 ( Rapid Move Z to top of material)
    G91 G1 f2000 (Enter incremental mode and set Linear Move & feedrate)
    z-2.5 ( plunge 2.5mm)
    y100 (Cut first mark)
    z3.5 (lift Z with 1mm clearence)
    y-100 x10 (back to rule start and increment 10mm)
    ( Repeat these 4 lines for every 1cm rule mark and every 10cm change y50 & y-50 to 100)
    z-3.5 (plunge tool 2.5mm @ 500mm/min)
    y50 (cut first rule 50mm long)
    z3.5 ( lift Z leave 1mm travel clearence 2.5mm + 1mm)
    y-50 x10 ( back to line start and increment 10mm)
    So go on give it a whirl you'll be surprised what you can do and having an intended goal really makes learning software easier and more rewarding.!
    It's a 6th rule I want to make son can chart the kids as they grow.
    As for G codes I would not know where to start as I can't find the Mrs G spot never mind understand Get code (is there a forum on how to find a woman's G thingy )
    I also want to put some text on it like the kids DOB and names.
    Now I know I will need to segment the plan because of the size of my machine.
    I will just have to man up and learn.
    Quote Originally Posted by Aaron74 View Post
    Not really a "Man up" thing more case of a having crack with nothing to loose train of thought.! . . . . Maybe give it a go and then ask about any area you struggle with. Like I say I find it's much easier to learn software when you have a goal in mind.
    Also while learning g-code isn't needed to work a CNC machine it really does help with understanding what machines doing or going to do. It's much simpler than most realise with very few commands and worth taking the time to learn.
    The G-spot is myth made up by women to drive us blokes fucking mental. . .Lol
    I ran the code but the spindle didn't start I even tried twiddling it's G-o button, but I ended up with woodworker's finger, G-cramp
    Oh twiddling the thing into life is well beyond G-o buttons now you need a diving helmet and Oxy/helium mix to find the Mmm3 spot. .
    So update time.
    well i've done one that i'm happy with with ( but have a big pile of fire wood lol)
    I have to use a cad program to do the design and ensure the size's where correct.
    then import it to Vcarve add the text.
    work out how to use the tile function.
    Well all i can say is that i'm glad I gave it ago, the only dow side is that now other ppl want then and it was meant to be a 1 off.
    Here is a pic of how it looks.
  1. Torch Height control
    By Bobp in forum General Electronics
    Last Post: 09-12-2019, 04:46 PM
  2. Z axis height setter
    By phill05 in forum General Discussion
    Last Post: 29-11-2016, 01:14 PM
  3. Height Mapping?
    Last Post: 26-10-2012, 11:40 PM
  4. NEW MEMBER: kids charity needs help
    By grazza in forum New Member Introductions
    Last Post: 05-05-2010, 05:00 PM
  5. Setting Z height with an ER32 collet
    By Robin Hewitt in forum Machine Discussion
    Last Post: 27-03-2010, 09:16 PM
