Thread: Evening all
The front baffle is modelled, offset height, all shaped, looking at curved cabinets which is what lead me to think about a CNC machine !!!
Currently running some design concepts and materials through FEA analysis....... Could be going wood...... well de havilland built the mosquito and Morgan a chassis for years, I figure a CNC machine can't be so difficult :)
24-11-2014 #2
24-11-2014 #3
Exactly, that's the beauty of wood, it's flexible so doesn't snap like a carrot. There seems to be a trend recently with people wanting to make wooden machines, they've probably been looking on US forums.
Personally I don't have the strength to keep saying, "don't do it", so all I'll say is that after building a steel and aluminium machine there is no way a wooden contraption is going to come anywhere near, and I've been working with wood for a long, long time.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
25-11-2014 #4
Nothing like a challenge
.... To be more exact, 18-25mm Marine Ply, used in "I beam" configurations... maybe with some Aluminium parts in the gantry. The base will be Ply. If I had a cast iron bed plate, hold down clamps and a MIG set yeah I'd make a steel one... but I don't, neither do I want a warped heat distorted frame to shim up and true later.
Aiming at around 1200 x 800 bed size to achieve 1000x600 cutting area. (don't want loose all my garage, as it's only a single!)
Tricky to get some of the stress and modulus data for Ply, anyway current scheme is suggesting via FEA to be 0.02mm deflection with a 50Kg load about the motor mounting platform. (circ 12Kg mass, which I can reduced). Not a bad start I though.
Can't image to see that load on a cutter, but it helps to pin point the week areas. Any idea what the lateral forces are on a cutter?
I'll scheme up an Aluminium gantry with some extrude section 8, 160x80, and end plates to compare, then work out the easiest build sequence. That will required some machining to be contracted out... Some perhaps someone in the Midlands will be able to help out :)
I'll post up a design thread when I've got a bit more data and detailed laid down...... appreciate all the comments, interesting and fun stuff.
25-11-2014 #5
Have a look at this product far more stable than wood / ply / mdf, it is quick to cut and assemble, not cheep but you would gain in build time.
Run your design calc's with this product and see results yourself.
http://www.meditetricoya.com/products/medite-tricoya
NEW MEMBER: good evening gents
By fastcarl in forum New Member IntroductionsReplies: 2Last Post: 01-06-2010, 10:07 PM -
NEW MEMBER: Good evening all.
By monza in forum New Member IntroductionsReplies: 2Last Post: 28-12-2009, 08:53 PM -
NEW MEMBER: Good evening.
By itbookham in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 08:46 PM -
NEW MEMBER: Evening all.....
By HiltonSteve in forum New Member IntroductionsReplies: 9Last Post: 14-05-2009, 02:40 PM
