22-11-2014 #5
I would say the easy place to start would be just to use db plaster board on all the walls and sealing and and ideally double board it staggering the joints if they are stud walls insulate behind in the cavity with Fiberglass wool if not build some wooden frames and stud it out.Its is basically just a very dense type of plater board something like 36kg a sheet and then get or make some extra thick doors with good seals.
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
Your views and opinions on the Black Cat CNC Machine 600x900 please
By Rockeyes in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 31-05-2012, 05:21 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM
