Have a look here http://www.fermacell.co.uk/#_sub1675
If you give them a ring they will send you the Orange Book and this will give you all the construction techniques for various applications, Fermacell boards are very dense and are designed for soundproofing and fireproofing, i am using it in my house, if you are doing it yourself you can request one man boards these are 1200 x 1200 and relatively easy to handle, also the panels are glued together when you install them and it makes a crackin job.
regards
Mike
22-11-2014 #2
Thank for the link Mike I had a quick look on the site. I will ask them to send me the Orange Book and have a read. What you say about the boards sounds good I look forward to learning more about them.
Many thanks
Suesi
22-11-2014 #3
There are links on the Fermacell site for youtube videos that show the whole process, if you use the steel preformed stud system it looks a doddle, you can download the Orange Book from the link i gave you, my installation is a nightmare as i made the mistake of using Celcon Solar blockwork on the internal walls and trying to get a fixing is a mare, as you can't apply any weight on the screws or they just start rotating, so for any chance of a decent fix all the battens have to be re machined to get them parallel straight and square then lubricate the screw and softly softly till it hardens up but no more.
Regards
Mike
22-11-2014 #4
If its brick wall don't worry to much about covering them, no sound produced by any machine is likely to to penetrate it with much energy left unless the sound source is applied directly to the wall e.g. drilling into the wall with a hammer drill. If you are on a budget then something like old carpet + underfelt inside the ceiling between the trusses will makes a good difference. The basic idea is to get things as air tight as possible and damping where you cannot make it air tight. Think along the lines of how well modern cars are sound proofed.
22-11-2014 #5
Hi michejc,
Thanks for the views and tips I have lots of thinking to do. If I have the workshop built I want it done well so I would spend a reasonable amount and just do it once.
Many thanks
Suesi
03-05-2015 #6
Apologies for being late to the party, but if you want some interesting reading on sound reduction, check this link:
http://downloads.bbc.co.uk/rd/pubs/reports/1991-09.pdf
The BBC have put a lot of time into investigating lightweight sound reduction ideas. They're looking at it from the perspective of recording studios rather than workshops but, if you don't mind it getting a bit technical, the PDF linked might give you a better idea of some of the considerations involved.
05-05-2015 #7
A while back while i was working in a the depths of an RFA Vessel. We got to thinking about noise reduction or even noise cancelling. We tried a few methods and was semi successfull use a mike and a laptop output the opposite noise. In a small ish place it could work quite well. The computer would in realtime monitor the noise created and output the opposite noise to cancel it out. If i can find the software i used ill post it up.
I know its slightly ott and probably not worth the time, but for al diyers its a great little project.
The principle is that the software generates a inverted sound, essentially cancelling out the sound around you.Last edited by Jester; 05-05-2015 at 06:44 PM.
The Following User Says Thank You to Jester For This Useful Post:
07-05-2015 #8
22-11-2014 #9
Thank for the msg Mike. It is handy to know of your issues and I am glad you got it right, I bet it will be worth it in the end. I will watch the Youtube videos for sure and download the book.
Many thanks
Suesi
THC Setting Issue?
By Davek0974 in forum Plasma Table MachinesReplies: 8Last Post: 17-10-2014, 07:53 AM -
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
Your views and opinions on the Black Cat CNC Machine 600x900 please
By Rockeyes in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 31-05-2012, 05:21 PM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM
