Page 2 of 6 FirstFirst 1234 ... LastLast
    Cnc4u have 2500mm x 20mm screws which I was wondering about using although I do also have enough mod 1.5 rack here that needs a home or selling.
    were about's are you?
    Im In Hebburn, Tyne & Wear.
    Ive just changed the pinions over on the drives to mod 1 pinions so not really any use to me pal.
    I thought you had used those drives on another build? The rack and pinnion does seam nice on my build I have done but I was thinking that screws would be the way to go posable. if you have the drives already though then your half way there.
    Yeah they are on the 4x4,it was a 3mtr but had to cut it down due to a large contract coming in and needed the space. ive now sorted the shop so that it would not get in the way
  5. #15
    OK ive managed to get a little more done this morning before the wife started chewing my ear.
    Fingers crossed if all pans out, i can have the frame uilt for friday and into powdercoat for saturday/Monday.
    Im thinking about servos on the X & Y and a leadshine on the Z. any suggestions?
  6. #16
    Best advice with regard to Z axis is to put rails on front plate, bit where the spindle mounts, and bearing blocks on back plate, i.e. opposite to what you've shown.
  7. #17
    Is this to make it more rigid..? From the commercial ones ive seen they are all mounted like this. as i thought with it being the Hiwin rails with less play than the SBR stuff
    I dont suppose anyone knows what this bar is for on the bottom of the gantry of the Techno machines do they? Im guessing that when its tightened it pulls it square of some sort?
  8. #18
    Nevermind ive found ou what it is
    "a special steel backing beam and torsion bar are integrated into the axis for added stability. The torsion bar acts like a sway bar on a vehicle, which in turn keeps everything straight and taut when cutting loads change. The steel backing beam provides extra support to the linear rails, greatly improving the router's rigidity."
  9. #19
    Hi D man
    I would wait for conformation off one of our more experienced members but i would think the Z needs to be on the other side of the gantry so it is better centered over the X axis bearing blocks.
    Regards
    Mike
  10. #20
    Yeah ive been thing about this myself, The setup works on my 4x4, however thats only cuttin MDF and light plastic. i have been toying with the itea of vertical ones on this one, but the side to side motion worries me as im not connecting the gantry under the table.
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. RFQ: RFQ: Gantry in Aluminium plate
    By IanS1 in forum Projects, Jobs & Requests
    Last Post: 03-10-2014, 03:51 PM
  3. Strengthing a steel gantry.
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 07-06-2014, 09:11 AM
  4. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  5. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
