23-11-2014 #19
Normally Eddy I'd 100% agree with you but with such short travel then no I'd go with something like how it's set out now. Thou I would have the bearings on the front plate lower with next to no overhang and extend the spindle down in the clamps. This will give full support to spindle/front plate from the rear plate.
If longer travel then I'd set it out other way.
Derek I wouldn't mix servos and steppers and go with same on all axis. Not that they can't mix but it keeps electrics all the same and there won't be much difference in price. If your going with servo's or even steppers for that matter then suggest you get a decent motion control card. Definately will need one for servo's to get decent performance out of them.
Cast aluminium gantry router
By jrcast in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-02-2017, 08:13 PM -
RFQ: RFQ: Gantry in Aluminium plate
By IanS1 in forum Projects, Jobs & RequestsReplies: 1Last Post: 03-10-2014, 03:51 PM -
Strengthing a steel gantry.
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-06-2014, 09:11 AM -
BUILD LOG: Monster fixed gantry router for aluminium & wood
By jonboycnc in forum DIY Router Build LogsReplies: 9Last Post: 12-01-2014, 11:26 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM
