  1. #2
    OK so... We start off with a nice and heavy base.
    Base is constructed of 100 x 100 Cold rolled box section for the main legs and 100 x 60 on the base table.
    80 x 80 Extrusion will run alone each side of the table with smll slots in the box section to allow for slight adjustment. then locked off with angle brackets
    Im still not sure if i should lose the leg in the centre to allow me to run a brace under the table to help a little more to aid the crabbing of the gantry. this will also open up the possibility of using rotating ball nuts in the future.
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. RFQ: RFQ: Gantry in Aluminium plate
    By IanS1 in forum Projects, Jobs & Requests
    Last Post: 03-10-2014, 03:51 PM
  3. Strengthing a steel gantry.
    By gavztheouch in forum Gantry/Router Machines & Building
    Last Post: 07-06-2014, 09:11 AM
  4. BUILD LOG: Monster fixed gantry router for aluminium & wood
    By jonboycnc in forum DIY Router Build Logs
    Last Post: 12-01-2014, 11:26 PM
  5. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
