Thread: Best place for hard stops?
If you envisage that the likelyhood of a nasty crash is high then supply your stepper PSU through a cut-off circuit with switches at the ends of travel, if you use a multi-pole, double throw relay you can E-Stop your spindle controller and E-stop your control software at the same time.
No matter how kind your hard stops are if your machine winds into them hard you're no better of than if you hadn't fitted them at all,
- Nick
25-11-2014 #2
Thanks for the advice gents. I like the idea of avoiding running into any hard stops by using additional switches to disable the drivers or cut the power to the drivers and I'll look into that a bit more. I wanted a foolproof way in case something goes wrong and I run thru my limit switches and these additional switches you suggest will do exactly that.
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
RFQ: Why is it so hard...
By ktc in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-08-2013, 08:05 PM -
How hard is it to make diy PCBs if you’re a Noob ?
By Fivetide in forum General ElectronicsReplies: 18Last Post: 05-04-2013, 12:10 PM -
RFQ: Hard colour anodising
By Mixster in forum Projects, Jobs & RequestsReplies: 10Last Post: 11-03-2013, 10:58 PM -
gcode stops mid way can anyone test..
By crossleymarko in forum CAD & CAM SoftwareReplies: 16Last Post: 22-04-2012, 12:45 AM
