Page 2 of 2 FirstFirst 12
    Quote Originally Posted by stirling View Post
    You could give this type of stuff a go
    Funny you should mention that, I posted something similar myself a few weeks ago, http://www.mycncuk.com/threads/8045-...3115#post63115 , but then forgot about it
    Could you not drill a series of holes along the lengths of all the sections, counter bore all the holes on the outside two.
    Insert threaded bars through the holes and tighten it all together with Nyloc locknuts.
    Done. Holes drilled right through, 8mm rod with dome nuts at the end and captive channel nuts in the 45deg extrusion.
    Counterbores to allow a socket to be placed over the dome nuts was cut on the cnc router, it cut it like butter.
    I was going to put 6mm aluminium top on it but to keep cost down I found some spare 10mm waterproof melamine faced plywood.
    Also after using supported rail for the first time I can safely say that even though it works great for this application I would not use it myself for building a cnc machine.
ID:	14049Click image for larger version.
ID:	14050Click image for larger version.
    Nice job Eddy, is that a Felder ?
    Regards
    Mike
  5. The Following User Says Thank You to mekanik For This Useful Post:
  6. #15
    Regards
    Mike
    Same company but slightly cheaper 'Hammer' brand.
  1. Aluminium Repair and joining without welding
    By EddyCurrent in forum Metalwork Discussion
    Last Post: 28-12-2014, 11:41 PM
  2. BUILD LOG: Aluminium Extrusion Question
    By PuppyWoofie in forum DIY Router Build Logs
    Last Post: 13-11-2012, 02:19 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. Aluminium Extrusion suppliers?
    By m_c in forum General Discussion
    Last Post: 12-04-2011, 01:23 AM
  5. Tapping Aluminium extrusion
    By Web Goblin in forum Metalwork Discussion
    Last Post: 03-01-2011, 03:13 PM
