Thread: Accurate Strong Gantry
Yes some corrective action should be done .
The gap in the middle just represents the place of the single ball screw in case of narrower machine
regarding the rail I would use one like this which is regular type now
The problem is as you pointed to it at my case only the upper row of ball hold the load but the moment resistance is good that occurs at start-stop and direction change
I have no experience using it but suppose it works -the catalogue also mention it as possible mounting arrangement
Because of my 100kg+ heavy moving gantry I have drooped this design and go with fix gantry where the moving Z will be balancedLast edited by vargai; 07-12-2014 at 04:25 PM.
07-12-2014 #2
07-12-2014 #3
Ok, I'm a bit confused. You keep saying fixed gantry but then you show a bed with rails on the side.
Is this the bit that will be moving? If so I would have said that it is not the best way to do it. Moving beds should have the rails underneath and at approx. third points or a quater in.
That way the rails are supporting the load better and are closer together so you can get away with one ballscrew.
As you have drawn it the bed can bend in the middle under load.
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
