Thread: Accurate Strong Gantry
19-12-2014 #17
Looks good. I would probably extend the gantry uprights down to the floor so the more area would be available for welding and increase rigidity. the vertical rails could then drop down and increase the bearing spacing a bit more.
I think golden ratio is 2:1 so if the y axis is 800mm wide then you need 400mm bearing spacing. as you pointed out one change can affect another and you will need to look at flex in the mounting plates and possible bracing,
Do you think the gantry uprights need bracing as well? looks quite tall
It may have already been mentioned but how to plan to keep all the surfaces perfectly aligned whilst welding and given the surface tolerance on steel c section?
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
