Thread: Accurate Strong Gantry
I am a fan of taper locks or similar shaft lock- simple fast and not expensive - is it good without parallel key?
27-11-2014 #2
Then you will need dial indicator and mess around just to center it properly on the shaft. Cause they are not self centering to the needed tolerance. Plus are heavy. Best would be tight fit and you or somebody localy to machine you the pulleys from aluminum.
27-11-2014 #3
thanks, already I can go further with design
BR
István
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
