  1. #16
    Looks good. I would probably extend the gantry uprights down to the floor so the more area would be available for welding and increase rigidity. the vertical rails could then drop down and increase the bearing spacing a bit more.
    I think golden ratio is 2:1 so if the y axis is 800 mm wide then you need 400 mm bearing spacing. as you pointed out one change can affect another and you will need to look at flex in the mounting plates and possible bracing,
    Do you think the gantry uprights need bracing as well? looks quite tall
    It may have already been mentioned but how to plan to keep all the surfaces perfectly aligned whilst welding and given the surface tolerance on steel c section?
    Extending the gantry uprights down seems good idea -this node should be rethink with the bracing and reinforcement plates in profiles.
    My aim is to design parts that can be done by both DIY and machining method.
    machine bad is Ok -it has surfaces to be leveled on top -preferably positioned on the same level-that is way stand the gantry leg here at the moment
    Y beam is the same -can be done on both way
    Z beams will be separated and bolted so it is similar to Y -I do not want to weld a U form and do something with frame -it makes my life hard
    rather to make strong flange nodes and the careful assembly and adjustment will give the accuracy (especially the two parallel surfaces)
    Nodes will be oriented and fixed with parallel pins.
    That is only may plan for now -God knows nothing about it.
  2. BUILD LOG: A sufficiently strong machine
    By Jonathan in forum DIY Router Build Logs
    Last Post: 29-03-2014, 10:40 PM
  3. Accurate Tape Measure?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 26-05-2012, 04:41 PM
  4. NEW MEMBER: Strong 1212DS - any good?
    By MrWiz73 in forum New Member Introductions
    Last Post: 29-03-2011, 11:13 AM
  5. Bit OT - accurate timing
    By m_c in forum General Electronics
    Last Post: 18-05-2009, 01:16 PM
