Thread: Accurate Strong Gantry
31-12-2014 #22
I have downloaded some kind of study about machining force and my
goal on 1000 N is not oversized requirement. I hope I can use max DIA 10-12 mm with moderate technology and dia 30-35 face mill on same way.
The machine will give the right answer and I will give a "reluctant" acceptance to it. I do not care if some work take a while since I will use this machine on one off and small batch production. With good strategy and preparation I even can compensate it but not bother if not. I have a day time job so it will be a free time profitable passion.
Regarding the design I am rather analyst type and it is important and challenge for me to see the theory behind the result.
Everything happens according to some kind of theorem and if one catches the rule then catches the physical result.
So thank you for your help in advance.I still have to adjust my plan a bit and revert it later.
I use Solidworks but the estimating the elastic deformation (strength ) would be a big help too.Last edited by vargai; 02-01-2015 at 09:32 PM.
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
