Thread: Accurate Strong Gantry
12-01-2015 #16
It was not criticism just gathering data for a steel based light weight moving gantry DIY router that can be used in its scope and additionally I can check , try some solutions. I red about HSM spindle and HSM Al milling and aware of that this is also a wide spectrum so I will be happy with the result that a router can give.
Not forgetting the steel I am planning to attach an easy removable really small, geared spindle driven by the HS one with belt or directly coupled. (EDIT: i see now that the belt not good at this speed) In this method the supposed extension of the original spindle would be only about 60-80 mm and the force not bother the main spindle bearings
With 1:0,5 ratio (12000-to 6000 rpm) and quite enough torque I probably can make a typical steel milling with DIA 4-5 mm mill.
This would be making opening on a flat parts of electrical enclosures ( mainly doors) and mainly Dia 30,5 mm holes for push buttons.
The only problem is that the thickness is 2 mm but I suppose a 3kW spindle can do it with full DOC( the pre drilling- hydraulic method works but too slow and there are other shapes). This will not be bottleneck if I cannot do it just an idea.
pls adjust me if someone has experience.
One question about the steppers:
Normally they do their job and do not care of step loss and go on.
Is there any no too expensive mean, method to persuade them to stop at step loss and not multiply the mistake.
ThanksLast edited by vargai; 13-01-2015 at 08:34 PM.
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
Accurate Tape Measure?
By Tenson in forum Tool & Tooling TechnologyReplies: 19Last Post: 26-05-2012, 04:41 PM -
NEW MEMBER: Strong 1212DS - any good?
By MrWiz73 in forum New Member IntroductionsReplies: 0Last Post: 29-03-2011, 11:13 AM -
Bit OT - accurate timing
By m_c in forum General ElectronicsReplies: 3Last Post: 18-05-2009, 01:16 PM
