29-11-2014 #10
So what you need is someone with a IP-M to test this for you.!!. . . . . Ermmm
Well It just so happens I know a guy, who knows a guy, who's got a friend who knows a Gal, who's brothers got a couple sitting around doing nothing. .
Ok I'll try and test how it works for you. Not got a dual axis machine in a build state to test just at minute but I'm sure I can Rig up something to test how the motors sync and home on the bench.!. . . . Leave it with me a few days(weeks,months,years!!)
I've Nagged CSlabs brains out for this option since I started using these and it was mentioned that it couldn't be done due to hardware restrictions so I'm intrigued my self.?
I suspect it will work just like any other mach3 motion controller in that each motor just hits the switch and backs off. The IP-S works the same with steppers, thou it can HOME using the Index signal of servo encoders or if shaft encoders are fitted, where the IP-M can't do this I believe.
The IP-S also has an option to measure the trip error between switches and correct. This works very well because I tested it the other week using dial gauges and setting a large error. It brought it back perfectly to within 1000's/mm.
It also the option to measure and Not correct the error just display error in the plugin.
Know to me the this is useful but not like your probably thinking.? It's useful to me for setting the switches accurately as it works out the error between them so I could set the gantry square without twisting the gantry to make square, Which you don't want or need too ! . . Now I'm sure Golden Balls could easily do all this with the Pic up is arse.!! . . But I'm into using machines which means I want a quick way to set the machine accurately and forget not thrashing the few remaining bits of gray matter or pulling my Togger over capabilty's of Pic.!
I'll most a Vid if I get time.Last edited by JAZZCNC; 29-11-2014 at 11:51 AM.
ES-D1008 + CSMIO/IP-S wiring
By Matt81 in forum CS-Lab (CSMIO)Replies: 3Last Post: 03-05-2014, 10:56 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
By Greeny in forum Control Hardware & SystemsReplies: 20Last Post: 14-11-2013, 11:59 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
